feri.visky Postat Aprilie 11, 2015 Partajează Postat Aprilie 11, 2015 am primit... Multumesc! Link spre comentariu
feri.visky Postat Aprilie 23, 2015 Partajează Postat Aprilie 23, 2015 ...da' n-ati mai facut nimic?! Nu cred ca ne-am dezumflat asa de repede... Link spre comentariu
Patefon Postat Aprilie 23, 2015 Partajează Postat Aprilie 23, 2015 Se lucrează printre picături si in liniște. Eu am modificat o sursa sa scoată 19V si îndată ce am transformatorul de filamente gata ma apuc sa torn o cutie. Link spre comentariu
bmsorin Postat Aprilie 23, 2015 Autor Partajează Postat Aprilie 23, 2015 Da, asa este, pozele sunt facute de Sebi (in continuare este in teste "stresante" supus de catre Sebi). Link spre comentariu
sebi_c Postat Mai 4, 2015 Partajează Postat Mai 4, 2015 (editat) Cateva teste cu uTracer intr-o forma preliminara! S-au folosit doua programe, respectiv Utracer original si uTmax. De asemeni si modelul generat automat de uTmax: library format: LTSpice***************************************************** PentodeD model parameters created with uTmax www.bmamps.com* library format: LTSpice* DERK Pentode with screen current model.SUBCKT 12J1L_1 1 2 3 4 ; P G2 G1 C X1 1 2 3 4 PentodeD+MU=18.959940 EX=1.420077 KG1=1284.525024 KP=113.195747 KVB=0.442139 KG2=inf als=nan be=nan Aokg1=-0.000001 Ookg1mOokG2=0.000778 + RGI=2000 CCG1=0.0P CCG2 = 0.0p CPG1 = 0.0p CG1G2 = 0.0p CCP=0.0P.ENDS 12J1L_1****************************************************.SUBCKT PentodeD 1 2 3 4; A G2 G1 CRE1 7 0 1MEG ; DUMMY SO NODE 7 HAS 2 CONNECTIONSE1 7 0 VALUE=+{V(2,4)/KP*LOG(1+EXP(KP*(1/MU+V(3,4)/SQRT(KVB+V(2,4)*V(2,4)))))}E2 8 0 VALUE = {Ookg1mOokG2*(1-1/(1 + be*V(1,4))) + Aokg1*V(1,4)}G1 1 4 VALUE = {0.5*(PWR(V(7),EX)+PWRS(V(7),EX))*V(8)}G2 2 4 VALUE = {0.5*(PWR(V(7),EX)+PWRS(V(7),EX))/KG2 * (1+ als/(1+be*V(1,4)))}RCP 1 4 1G ; FOR CONVERGENCE A - CC1 3 4 {CCG1} ; CATHODE-GRID 1 C - G1C4 2 4 {CCG2} ; CATHODE-GRID 2 C - G2C5 2 3 {CG1G2} ; GRID 1 -GRID 2 G1 - G2C2 1 3 {CPG1} ; GRID 1-PLATE G1 - AC3 1 4 {CCP} ; CATHODE-PLATE A - CR1 3 5 {RGI} ; FOR GRID CURRENT G1 - 5D3 5 4 DX ; FOR GRID CURRENT 5 - C.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N).ENDS PenthodeD Editat Mai 4, 2015 de sebi_c Link spre comentariu
feri.visky Postat Mai 5, 2015 Partajează Postat Mai 5, 2015 Sunt un pic dezamăgit de (prea multe) teste... Am crezut că la o comandă fermă, primim ceva "ready made"... Poate nu am înţeles... Link spre comentariu
bmsorin Postat Mai 5, 2015 Autor Partajează Postat Mai 5, 2015 In principiu, daca comandam tot kit-ul, 220Euro, pe langa asamblare (lipit componente) tot trebuiau facute teste/reglaje dupa cum se specifica si in manualalul de pe site. Link spre comentariu
sebi_c Postat Mai 5, 2015 Partajează Postat Mai 5, 2015 (editat) Sunt un pic dezamăgit de (prea multe) teste... Am crezut că la o comandă fermă, primim ceva "ready made"... Poate nu am înţeles... Ready made este atunci cand primesti placa gata facuta, reglata si fara prea multe alte operatiuni la punerea in functiune! Noi ne-am angajat intr-un proces mai laborios. Ceea ce era de facut, eu am facut si cred ca functioneaza asa cum o fac si cele facute de autor. Calibrarea este un proces destul de laborios, care trebuie facut construind fiecare etapa indicata de autor. Pe mine m-a interesat si corectitudinea si acuratetea procesului de masura (chiar si o curiozitate), asta fiind o cauza ca am intins-o mai mult. Altfel, am mai avut si altceva de facut decat tester, desi am consumat destul timp pentru al pune la punct. Din punct de vedere constructiv, uTracer este un aparat de dificultate medie spre ridicata. Are unele sensibilitati, dar pana la urma este o unealta buna. Remarcabil e ca poate genera modele spice direct dupa lampa testata si intr-o paleta larga de tipuri de modele. Este un model care simuleaza bine si comportamentul grilei ecran Deja au primit piesele si placile cei care le-au platit. P.S. Aici este atasat un plot cu caracteristicile de iesire ale unui 6J1P (uzat) realizat cu placa d-lui Visky! Editat Mai 5, 2015 de sebi_c Link spre comentariu
hixpp02 Postat Mai 6, 2015 Partajează Postat Mai 6, 2015 Este foarte bine asa, mai invata ceva omul construind - parerea mea. Multumiri inca odata tuturor care au depus efort in acest proiect. Link spre comentariu
sebi_c Postat Mai 6, 2015 Partajează Postat Mai 6, 2015 (editat) Un plot de pe o lampa 6P3S! Editat Mai 6, 2015 de sebi_c Link spre comentariu
bmsorin Postat Mai 6, 2015 Autor Partajează Postat Mai 6, 2015 In ton cu hixxpp02, tin sa-i multumesc si eu D-lui Sebi pentru ajutorul acordat acestui proiect, fara dansul probabil ca ma fi clonat cablajul autorului. Dupa ce am primit placile noastre, am vazut ca sunt mult peste cele ale lui Roland. Asta cred ca poate fi un exemplu de proiect comun la sectiunea tuburi, care s-a finalizat. PS. momentan mai am de platat cate ceva la al meu, plus sa-mi vina niste nimicuri... o sa revin cu poze. Link spre comentariu
Patefon Postat Mai 6, 2015 Partajează Postat Mai 6, 2015 A ajuns pachetelul cu piese. Aoleu ce mititele sunt!!! Pareau mai mari pe schita! 1 Link spre comentariu
sebi_c Postat Mai 6, 2015 Partajează Postat Mai 6, 2015 (editat) 6P3S pana la 400V! La tensiuni mici se observa efectul dinatron. PS: 6P3S plot cu uTmax si model spice (mai trebuie puse capacitatile dintre electrozi). ------------------------------------- * library format: LTSpice***************************************************** Pentode model parameters created with uTmax www.bmamps.com* DERKE Pentode with screen current and secondary emission model.SUBCKT 6p3s 1 2 3 4 ; P G2 G1 C X1 1 2 3 4 PentodeE+MU=9.131610 EX=1.363034 KG1=523.410706 KP=33.292908 KVB=0.505996 KG2=inf als=nan be=nan Aokg1=0.000001 Ookg1mOokG2=0.001911 + RGI=2000 CCG1=0.0P CCG2 = 0.0p CPG1 = 0.0p CG1G2 = 0.0p CCP=0.0P.ENDS 6p3s****************************************************.SUBCKT PentodeE 1 2 3 4; A G2 G1 CRE1 7 0 1MEG ; DUMMY SO NODE 7 HAS 2 CONNECTIONSE1 7 0 VALUE=+{V(2,4)/KP*LOG(1+EXP(KP*(1/MU+V(3,4)/SQRT(KVB+V(2,4)*V(2,4)))))}E2 8 0 VALUE = {Ookg1mOokG2*(1 - exp( PWR(-be*V(1,4), 1.5 ) ) ) + Aokg1*V(1,4)}G1 1 4 VALUE = {0.5*(PWR(V(7),EX)+PWRS(V(7),EX))*V(8)}G2 2 4 VALUE = {0.5*(PWR(V(7),EX)+PWRS(V(7),EX))/KG2 * (1+ als/exp( PWR(-be*V(1,4), 1.5 ) ) )}RCP 1 4 1G ; FOR CONVERGENCE A - CC1 3 4 {CCG1} ; CATHODE-GRID 1 C - G1C4 2 4 {CCG2} ; CATHODE-GRID 2 C - G2C5 2 3 {CG1G2} ; GRID 1 -GRID 2 G1 - G2C2 1 3 {CPG1} ; GRID 1-PLATE G1 - AC3 1 4 {CCP} ; CATHODE-PLATE A - CR1 3 5 {RGI} ; FOR GRID CURRENT G1 - 5D3 5 4 DX ; FOR GRID CURRENT 5 - C.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N).ENDS PenthodeE Editat Mai 6, 2015 de sebi_c Link spre comentariu
victordascalescu54 Postat Mai 7, 2015 Partajează Postat Mai 7, 2015 Scuze ca intervin asa pe nepusa masa in acest topic, dar urmarindu-l, v-as face intrebarea daca asa ceva (cele doua lincuri) nu ar putea macar in parte suplini functiile analizorului de tuburi la care lucrati. Eu caut ceva relativ simplu (sunt la nivelul 1 spre doi hobby) dar n-am ce face si sunt indragostit de lampi si sunetul lor. http://www.ebay.com/...=item3a7aa3ba39 http://www.ebay.com/...=item3cc066bffd Link spre comentariu
bmsorin Postat Mai 7, 2015 Autor Partajează Postat Mai 7, 2015 Scuze ca intervin asa pe nepusa masa in acest topic, dar urmarindu-l, v-as face intrebarea daca asa ceva (cele doua lincuri) nu ar putea macar in parte suplini functiile analizorului de tuburi la care lucrati. Eu caut ceva relativ simplu (sunt la nivelul 1 spre doi hobby) dar n-am ce face si sunt indragostit de lampi si sunetul lor. http://www.ebay.com/...=item3a7aa3ba39 http://www.ebay.com/...=item3cc066bffd De la primul link pus de dvs. a pornit totul. Gasiti la inceputul toicului expuse pareri despre cele 2 module. Cineva de pe diyaudio chiar le-a integrat intr-un aparat, dar stiu ca avea ceva probleme la masuratori (practic, nu 'desena' corect curentul pe grafic). Acum, parere personala, daca va satisfac caracteristicile din primul link... e ok, daca vreti mai mult, comandati un kit de la Roland. Link spre comentariu
