Cod sursa 2.4 TFT LCD Shield
vasile eugen
Saluare.Sunt la inceput de drum cu acest sistem de dzvoltare.Am achizitionat un Arduino uno R3 impreuna  cu displaiul amintit in titlu.Am incercat coduri din saitul:http://nicuflorica.blogspot.ro/search?updated-min=2014-01-01T00:00:00%2B02:00&updated-max=2015-01-01T00:00:00%2B02:00&max-results=50
Dar nimic.Am  incercat sa fac din programe gasite si  in forma  copy/paste dar imi dadea erori la compilare.Am descarcat si librari si le-am pus  in fisierul librari de la arduino dar nimic.Ma poate ajuta cineva  cu un cod pentru  atesta TFT-ul?Pe display 2*16 caractere am  facut teste si este OK.
  • Răspunsuri 8
  • nico_2010
    5
  • vasile eugen
   Tot nu merge .Eroare in continuare.
Acest cod imi compileaza:
// Touch screen library with X Y and Z (pressure) readings as well
// as oversampling to avoid 'bouncing'
// This demo code returns raw readings, public domain
#include <stdint.h>
#include "TouchScreen.h"
#define YP A2  // must be an analog pin, use "An" notation!
#define XM A3  // must be an analog pin, use "An" notation!
#define YM 8   // can be a digital pin
#define XP 9   // can be a digital pin
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
void setup(void) {
  Serial.begin(9600);
void loop(void) {
  // a point object holds x y and z coordinates
  Point p = ts.getPoint();
  // we have some minimum pressure we consider 'valid'
  // pressure of 0 means no pressing!
  if (p.z > ts.pressureThreshhold) {
     Serial.print("X = "); Serial.print(p.x);
     Serial.print("tY = "); Serial.print(p.y);
     Serial.print("tPressure = "); Serial.println(p.z);
  delay(100);
si acesta dar  nu este pentru tft-ul care il detin:
 Arduino TFT Bitmap Logo example
 This example reads an image file from a micro-SD card
 and draws it on the screen, at random locations.
 In this sketch, the Arduino logo is read from a micro-SD card.
 There is a .bmp file included with this sketch.
 - open the sketch folder (Ctrl-K or Cmd-K)
 - copy the "arduino.bmp" file to a micro-SD
 - put the SD into the SD slot of the Arduino TFT module.
 This example code is in the public domain.
 Created 19 April 2013 by Enrico Gueli
// include the necessary libraries
#include <SPI.h>
#include <SD.h>
#include <TFT.h>  // Arduino LCD library
// pin definition for the Uno
#define sd_cs  4
#define lcd_cs 10
#define dc     9
#define rst    8
// pin definition for the Leonardo
//#define sd_cs  8
//#define lcd_cs 7
//#define dc     0
//#define rst    1
TFT TFTscreen = TFT(lcd_cs, dc, rst);
// this variable represents the image to be drawn on screen
PImage logo;
void setup() {
  // initialize the GLCD and show a message
  // asking the user to open the serial line
  TFTscreen.begin();
  TFTscreen.background(255, 255, 255);
  TFTscreen.stroke(0, 0, 255);
  TFTscreen.println();
  TFTscreen.println(F("Arduino TFT Bitmap Example"));
  TFTscreen.stroke(0, 0, 0);
  TFTscreen.println(F("Open serial monitor"));
  TFTscreen.println(F("to run the sketch"));
  // initialize the serial port: it will be used to
  // print some diagnostic info
  Serial.begin(9600);
  while (!Serial) {
    // wait for serial line to be ready
  // clear the GLCD screen before starting
  // try to access the SD card. If that fails (e.g.
  // no card present), the setup process will stop.
  Serial.print(F("Initializing SD card..."));
  if (!SD.begin(sd_cs)) {
    Serial.println(F("failed!"));
    return;
  Serial.println(F("OK!"));
  // initialize and clear the GLCD screen
  TFTscreen.begin();
  // now that the SD card can be access, try to load the
  // image file.
  logo = TFTscreen.loadImage("arduino.bmp");
  if (!logo.isValid()) {
    Serial.println(F("error while loading arduino.bmp"));
void loop() {
  // don't do anything if the image wasn't loaded correctly.
  if (logo.isValid() == false) {
    return;
  Serial.println(F("drawing image"));
  // get a random location where to draw the image.
  // To avoid the image to be draw outside the screen,
  // take into account the image size.
  int x = random(TFTscreen.width() - logo.width());
  int y = random(TFTscreen.height() - logo.height());
  // draw the image to the screen
  TFTscreen.image(logo, x, y);
  // wait a little bit before drawing again
  delay(1500);
